Perform this procedure to disable Auto-sense on a specific port. You also have the option to disable Auto-sense on the port but retain the configuration that the system applied dynamically.
Disable Auto-sense on port 1/2 but retain the configuration. The dynamic configuration becomes a manual configuration and is visible in the show running-config output and can be saved to the configuration file using the save config command.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface interface gigabitEthernet 1/2 Switch:1(config-if)#no auto-sense enable convert-to-config Switch:1(config-if)#save config
The following table defines parameters for the no auto-sense enable command.
Variable |
Value |
convert-to-config |
Retains the Auto-sense configuration that the system applies dynamically on the specific port. The dynamic configuration becomes a manual configuration and is visible in the show running-config output. If you run the "no auto-sense enable" command without the "convert-to-config" option, then the configuration will be removed from the port and the port returns to the default state where VLAN 1 is assigned. |
